I have 2 issues. I split my tractor (L2800 HST) because I thought the cam clutch had gone out again, it was making the same noise as it did last time. They look good. I talked to a mechanic yesterday and said the cable may be out of adjustment. It doesn't appear to be. What else could be making the noise and the tiller quit spinning, gear box on tiller maybe? Is there a trick to get the tractor back together? I get the studs in the holes the collar on both splined shafts but I cant get it any closer together than the line up pins.
