I'm trying to replace a leaking seal on my 3 point hitch piston (hitch would raise and quickly leak down) and I don't know how to get it out of the cylinder.
It was suggested to use a magnet to pull it out but I don't have one strong enough. Also suggested was pulling it out with suction but I haven't had any success. And I really don't want to open the case for something that seems it should be so simple. I tried using the pump (using starter motor only and the cover bolted on loosely) to push it out but that just sprayed oil all over creation. Surely someone has done this.
All else failing I'm considering drilling into the top of the piston, tapping it and putting in a screw to pull it out. I have reservations about doing that though, but I'm stymied. I'm hoping someone on this forum has a better way to get the piston out. Any suggestions or advice?
Thanks,
Paul
Thanks,
Paul
