P Pharmere New member Equipment Kubota M6040 May 25, 2020 14 0 1 El Dorado, Arkansas Jul 11, 2021 #1 It’s not a Kubota but maybe y’all can help. How can I remove this roll pin so I can take the nut off? Trying to replace a shaft on my gear box. Attachments C8C15293-4B84-44E9-9825-883A5D9755CF.jpeg 424.4 KB Views: 285
J jimh406 Well-known member Lifetime Member Equipment Kubota L2501 with R4 tires Jan 29, 2021 2,997 2,364 113 Western MT Jul 11, 2021 #2 Here's a few techniques. https://itstillruns.com/tips-techniques-removing-roll-pins-5731780.html
mcfarmall Well-known member Equipment Kubota M5660SUHD, Farmall C Sep 11, 2013 1,447 1,744 113 Kalamazoo, MI Jul 11, 2021 #3 Sacrifice the nut. Reactions: 1 user
P Pharmere New member Equipment Kubota M6040 May 25, 2020 14 0 1 El Dorado, Arkansas Jul 12, 2021 #4 Thank you for the info. I ended up cutting it off with a torch
William1 Well-known member Lifetime Member Equipment BX25D, JD X754 AWS Mower Jul 28, 2015 1,487 681 113 Richmond, Virginia Jul 12, 2021 #5 A bit late but... I use a small slide hammer.
