Hey, I use my tractor for about everything around the property, when mowing the lawn it can seem cumbersome moving with the loader on. Being a B2400 I'm looking for a quick release option, for when I don't need to the loader, Thanks!
I don't know your tractor specifically but with many tractors the loader is an accessory. A couple of pins hold it to its frame which is bolted securely to the tractor. There is generally some sort of stand included with the loader to support it when removed from the tractor. You remove the pins then operate the loader to put it into the proper position. Add the support stand. Disconnect the hydraulic lines. Back away from the loader. Reverse the process to reinstall. It takes five to ten minutes.
