Reluctant Hydraulic cylinder gland nut removal.
joea
B21 TLB
Aug 2, 2020
94
9
Marbletown NY
Need to find a good relatively cheap tool to help remove a cylinder end cap, with "radial" holes, picture attached. I have tools to remove the ones with holes "on top". Seems like Kubota chose hole sizes a bit small for most tools for that cylinder diameter.
Bought a "gear wrench" set on Amazon, which had a video of a guy wailing away on it. Me? broke the pin off first try. And I am no King Kong. Eh, they do provide 4 or 5 sizes in the set and I needed to use the smallest on. So, guess there is that.
Regardless, I need to reseal these cylinders on a Kubota B21 bucket (TL421). The holes are 5mm max, OD is about 2 to 2.5 inches.
Don't want to take these to a shop, have seals and tools, and have done all the others myself.
I guess I could make up something, if I can find hardened steel rod for the pins, but, last resort. Things like pipe wrench and heat are further away than that.
Flintknapper
L2350DT
May 3, 2022
1,850
2,321
Deep East Texas
Stop using that method and get a pipe wrench. You can put the cylinder in a vice (if careful not to tighten too much) but easier to just leave it on the front loader until you've broken the nut loose.
6,115
You might get it started with a punch, striking it to go in a counterclockwise direction. 5mm isn't much of an opening to get anything into!
Fedup
262
85
Winchester
There's the right answer. I break the head loose while the cylinder is still on the machine. I never use the "special tools" that fit in the holes. A pipe wrench and if needed, a cheater pipe on that. If you're too picky to put up with a few scratches when you're done, then buy new cylinders and keep it all "shiny".
joea
B21 TLB
Aug 2, 2020
94
9
Marbletown NY
Got a replacement set of the spanners coming, but for now used a 24 inch pipe wrench to get it loose. Did not mark it up too badly. That's fine for the "Boom" cylinders, but the bucket cylinders have a smaller gland, and not as "thick" so it will be harder to get a pipe wrench on that. The pin spanner should work fine on those anyway.
The aftermarket seal kit seems to be working fine, so far. I'll do the other side in a few days.
