Relief valve
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
Va
I’ve got a loud whining sound on my B2650. I had a mechanic look at it and he said it possible could be your relief valve is going bad. About how much do they run and are they hard to install. Thanks for the help in advance
7,050
Have you done ANY diagnostics to confirm that "diagnosis"?
Have you checked to make sure all the hydraulics are working?
Have you checked to make sure you are not deadheading the system?
kcs 61
Apr 8, 2024
Va
Yea everything is working as it should. Loaded and 3pt is working fine. All the fluids are good. The hydraulic are running at 2450 psi
kcs 61
Apr 8, 2024
Va
Mostly when I use the loader or BH. And when I’m moving with WOT
