Releasing stress on 60" MMM tension belt
kubotabob
B2920, 60" MMM, FEL, Rear Blade
Aug 5, 2010
virginia, usa
When winterizing your MMM, do you guys remove the belt or do you just relieve the tension on the belt... also, is there an easy way to release the tension pulley from the spring?
thanks
Mingy
L3010 backhoe FEL, B2300, M9000
Jul 27, 2010
106
Ontario
I just leave it under tension. Hasn't been a problem after about 7 years or so. The big PITA with is with the bogey wheels, which cost a fortune and are badly designed - I have to replace one every ear or so.
If I recall, to release the tension, there is a swing arm you kind of unlatch.
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
654
986
Hayward Wi
I released mine this time. I used a crow bar for leverage on a tab and a 2x2 aginst the idler pulley and belt came off left hand spindle pulley no problem.
Can you understane what I'm trying to say?
kubotabob
Aug 5, 2010
virginia, usa
hey Toyboy, yea i understand. i will try that today. greatly appreciated to both of you for responding.
kubotabob
Aug 5, 2010
virginia, usa
yes i did. worked! thats one strong spring. so i greased all the zerks, released tension on the belt, replaced the blades with gator mulching blades and scraped the dried on grass from the belly and then pressure washed the whole MMM. stored it away in the shed, and now just waiting for the snow. again, thanks guys for all the help!
