Recommendations on post hole digger
5,191
9" if you can drill straight.....
if post is 6" by 6"....
6^2 + 6^2=36+36=72
square root of 72 is 8.5"
now if the " post is really a 6by6, it'll be 5.5" x 5.5" ,so lots of 'wiggle' room....
this would be for a 'dirt fill' not concrete. it concrete ,you'll need a bigger hole
Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
Aug 4, 2019
84
20
Cocolalla, Idaho
I did NOT tell him to rent one, offered him an option instead of having a local guy drill the holes. Please reread my post #10 again. Hopefully you read NOTAMs better.
He didn't say he had 10 holes or 1000 holes he needed done or when they were to be done.
I found out years ago it was cheaper to have a guy drill the holes than for me to BUY a PHD for any of the 4 tractors I owned back then. Also ZERO 'learning curve'. YOU buy the PHD and it'll take a few holes to figure it all out...time you might not want to waste,especially if only a few holes.
What most don't figure out ,is that while someone else is doing the drilling ,YOU have 'free' time to place the poles,so the job actually goes faster.
The huge problem with 3PH PHD is NOT having reverse. That omission can be a real PITA. Hydraulic PHD should have reverse, but will cost more money.
If our friend B737 keeps up the nasty, sarcastic ‘tude, he’ll be joining the unforgettable Sidecar Flip in the land of “sure glad his a** is out of here!”
5,191
thank you.glad I'm not the only one that sees that side of him.
maybe he don't like me cause the last 737 i flew was a -200 series ??
oh well. like life, days are getting shorter ,no time to worry about him
5,829
I love this... guy owns a tractor, asks for input for purchasing PSD, you chime in and tell him to rent one sub it out... WTAF of the day.
You take offense when someone offers an idea that "seems outside the box" of your thoughts? Often times that is where a good solution is. My guess is you are the type of person who enjoys working by yourself! Your WTAF emphasizes your rudeness.
B737
LX3310
Jun 9, 2019
2,024
2,200
not offended, just stating the obvious.
It's bewildering when members constantly suggest subbing out, or renting equipment for a task that falls well within the scope of our machines.
I (and others) offered what specific knowledge they have doing this task, not "outside the box" 😂 that isnt what OP asked for.
Hyperborean
L3902, LP FM2560, EA WRG 55, Split-Fire 3403, Wallenstein BXM42, and more
Apr 26, 2023
15
17
Land Pride has an auger that attaches to the front end loader and uses the 3rd function valve to operate. Model number is SA10 https://www.landpride.com/products/8868/sa10 series hydraulic post hole digger I have one but haven't used it yet but the main benefit of it over a 3ph version is that you can apply downward pressure and it can go reverse because it's controlled via hydraulics; which is helpful if you hit something that binds up the bit.
