Receiver question
bucktail
Jun 13, 2016
1,252
189
MN
The receiver on my Dakota has a closed front. I don't like the design but it is what it is. The design makes it bothersome to get the hitch in the last eighth of an inch or so. I don't think it would hurt anything if I cut a quarter of an inch off the back. Anyone have an opposing view?
5,786
Probably have some dirt, mud and crud in there. Take a screw driver and scrape around in there and blow out with air. If nothing works cut off a 1/4" off the hitch.
SidecarFlip
Banned
556
Not sure why the end is closed. It's just square schedule 60 tubing. Mine is open on the end and I don't believe cutting the end off would impact anything. Might be hard to cut it off however, not much room at the end to manipulate a saw.
bucktail
Jun 13, 2016
1,252
189
MN
No probably about it. It's mostly rust. My preferred tool is a manure tine from the loader that I bought, but the receiver buts right up against the end and if fights you for the last eighth of an inch or so because you can't get the corners clean.
CaveCreekRay
Jul 11, 2014
2,631
100
Cave Creek, AZ
Suggestion: Use a 4.5 metal or diamond cutoff wheel to bevel the lower forward end of the ball mount. Light pressure with a little "rocking" melts through and does a great job. Then some black touch-up paint and you are done!
bucktail
Jun 13, 2016
1,252
189
MN
All I know is, all the receivers on my Browns are God awful...other than Jarvis Landry.
Last time I had trouble with mine I soaked it in PB Blaster and hit it with a hammer for 15 minutes. Maybe you could try that? You'll probably need help getting them to hold still for it though...
