Hi, if you would have a moment please check out the video in the link below and tell me if you hear anything concerning.
I’ve been working through rebuilding the D650 on this pasture find. Today I cranked up the engine for the first time and it came to life! It’s idling pretty well, but I still see some smoke coming out and also a subtle “knocking” noise that I’m curious if you can pick up on video.
I hesitate to say “knocking” because it may just be the noise of the engine with no intake or exhaust manifolds.
youtube.com
I don’t know enough about diesels to know what’s normal. This re-built engine has run for less than a minute so far.
Will the smoke clear up after running it for a while? Does it sound normal?
Some details:
Original block was cracked.
Donor block had cam shaft and timing gears/cover. Nothing else. All other parts came from original block.
New oem piston rings.
new oem head gasket.
new rod bearings
Serviced injectors
Serviced fuel pump- totally mucked up.
Used same fuel pump shims from donor block.
lapped valves
Valve lashed to .007”
New gaskets
New headaches
New lessons learned.
Generally everything was cleaned and put back where it was.
Never done this before. Happy to hear it come to life but want it to be right.
Thanks!
Kubota D650 B6100 first start p2
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Some details:
new rod bearings
Serviced injectors
lapped valves
New gaskets
New headaches
Thanks!
