Rear tire pressure
powersrp
B3350
Apr 2, 2017
95
Indian River MI
Is the recommended pressures for the rear tires the same when they are filled with beet juice? Working on softening the ride, lots of mowing to do this summer. Can i drop air pressure a bit being the tires are filled? B3350. Turf Tires
Thanks
powersrp
B3350
Apr 2, 2017
95
Indian River MI
I have turf tires, filled, im just not sure if you still use the reccomended psi as an empty tire vs filled , the ride is ok, but when you bounce around for 8 hrs mowing, any help is a big help. maybe i should change the post label. hmm
BigG
Sep 14, 2018
1,949
765
West Central,FL
If you look on the side of the tire the pressure given is the maximum PSI. So yes you can lower the pressure but just a little air out will change the PSI quickly because there is little air in the tire to begin with since most of it is beet juice.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
With or without beet juice your tire pressure should be about the same. There will be a low end to the range of recommended pressures and you can run there but don't go below the minimum recommended pressure. You should have more pressure in your tires if hauling a load. A tire filled with air only has a much larger compressible volume than one filled with liquid. It is possible too much beet juice was put into your tires making the compressible volume uncomfortably low.
powersrp
B3350
Apr 2, 2017
95
Indian River MI
The answers i was looking for, I will try a cpl less pounds, i use a 3 point mower so not much weight on rear end.
Thank you’s
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
On my B2650 with turfs, recommended rear pressure is 14lbs. I run 10lbs in mine for the last 4yrs and made a big difference.
armylifer
Mar 26, 2013
1,958
701
Thurston County, WA
I have a BX1860 with tires that are one size larger (for BX2360). I run them loaded with windshield washer fluid filled to 70%. I fill the rear tires to 3 lbs psi. I keep the front tires at 22 psi and loaded with 70% windshield washer fluid.
When I had the stock tires on I also ran with 70% windshield washer fluid but I had 10 psi in the back and 22 psi front.
