Rear Tire Chains L3301
CommanderDave
L3301
Nov 1, 2022
Western Iowa
I'm struggling to determine what type of tire chains to buy for my L3301 4wd tractor with 15-19.5 NHS rear tires. The deep lug tires have liquid ballast and I do have a 3pt very heavy duty box blade that I can install for added weight. My dilemma is this: I have a concrete driveway and I use the front loader bucket to remove/plow snow, mostly using it's float function. When I do this I usually get down to, or close to, bare pavement. The other issue is I have a couple (downhill) locations on my 30 acre property that I need to get to when we have snow (sometimes a lot of snow, I live in western Iowa). I'd like to use the tractor to get to them, but the last time I tried I nearly got stuck and it took a long slippery time to get back. I'm looking for chains that won't tear up my concrete driveway yet are aggressive enough to get me through the snow. It's my understanding that twisted or square chains are the best for dual use on/off road, but are they robust enough for my needs? I'm thinking if my on-concrete use is limited, and I go at a slow speed, that I can go with something more aggressive. I know studded or V-bar chains are out. These are the candidates I'm considering:
https://tirechain.com/15-19-5-15-19-5-duo-grip-tractor-duo-grip-tire-chains-set-of-2/
https://tirechain.com/9-5-28-360-70...0-ladder-tractor-square-tire-chains-set-of-2/
https://tirechain.com/15-19-5-european-diamond-tractor-set-of-2/
Any information, recommendations, or previous experiences would be greatly appreciated. Thanks.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,172
1,569
Western MT
I think all of those are as aggressive as the ladder chains on mine. Mine work fine, so I think all of those would work fine.
They don't sell the model I bought any more, but this was the description.
1 × 9.5-28, 360/70R20, 11.2-24, 380/70R20, 15-19.5, 340/80R18, 355/80R20 Ladder Tractor Square Tire Chains Set Of 2
CommanderDave
L3301
Nov 1, 2022
Western Iowa
Those would be the description of the ones I listed second, the square tire chains. I do like them as they are square and described as heavy duty. I've heard that the ladder style of chains can slip down in between the lugs and not contribute to traction. Have you ever run them on pavement?
jimh406
Jan 29, 2021
2,172
1,569
Western MT
I only have a bit of my property that is asphalt up next to our house and garage. They work fine though. I haven't seen any damage to the asphalt. I have R4 tires, and they are loaded with Rimguard.
Almost all of my approximately 1/4 mile driveway is gravel.
