Rear PTO on 2650
LONGBOW42
B2650, loader, mowing, seeding, rake, post hole digger, rear blade
May 19, 2020
25
Chadds Ford, Pa
Hello,
Having difficulty engaging rear only PTO lever; anything I need to know?
Thanks,
UpNorthMI
May 12, 2020
850
568
Up North, MI
First you need to select "rear PTO" with PTO select lever.
When you use the PTO clutch lever to turn on the PTO, have your tractor at idling revs, once engaged, you can increase engine revs.
I attached instructions.
Good luck
LONGBOW42
May 19, 2020
25
Chadds Ford, Pa
Good luck
Thanks again!
