L LONGBOW42 New member Equipment B2650, loader, mowing, seeding, rake, post hole digger, rear blade May 19, 2020 25 2 3 Chadds Ford, Pa May 19, 2020 #1 Hello, Having difficulty engaging rear only PTO lever; anything I need to know? Thanks,
UpNorthMI Well-known member Lifetime Member Equipment L3200, L3901, MX5800, SVL75-2, KX040 May 12, 2020 850 568 93 Up North, MI May 19, 2020 #2 First you need to select "rear PTO" with PTO select lever. When you use the PTO clutch lever to turn on the PTO, have your tractor at idling revs, once engaged, you can increase engine revs. I attached instructions. Good luck Attachments B2650 PTO.pdf 202.1 KB Views: 314
L LONGBOW42 New member Equipment B2650, loader, mowing, seeding, rake, post hole digger, rear blade May 19, 2020 25 2 3 Chadds Ford, Pa May 19, 2020 #3 UpNorthMI said: First you need to select "rear PTO" with PTO select lever. When you use the PTO clutch lever to turn on the PTO, have your tractor at idling revs, once engaged, you can increase engine revs. I attached instructions. Good luck Click to expand... Thanks again!
