how to get rear arms working Kubota b2620 after fluid change,forgot to lower arms before change.
Can you stand on them to get them to their low point and then add the appropriate amount of fluid to get to the full level? If that does not work then report back.
front loader works fine.Does the tractor have a front end loader? If yes does that work?
no never heard of it.@kubotafreak makes a good point. Did you, or possibly someone else, close the 3 point drop speed valve under the seat?
light bulb just went off,might be problem,thanks, still a rookie!never heard of it.
