This is how my day went. So while working on my front wheel bearings I took a small shortcut. Rather than dragging the floor jack over I used the FEL to lift the front end off the ground, through the jack stands under the uprights, and lowered the tractor onto them. This resulted in the tractor balancing on the stands and the rear end also nearly lifting off the ground. After cleaning the complete mess that was my front hub casing and putting it all back together I noticed fluid leaking from the rear end. WTF! Did a seal let go when I unloaded the rear tires? Why does it look like its coming from the top of the diff, the only thing up there is the 3 point hydraulics.... damn it. How, why. WTH! Touch the fluid on the ground, nope, no way, there is almost no viscosity its as thin as water. Could there be water in my hydraulic fluid again. No not this much. Well let me get it on the ground and keep looking. As I go to get back on it to get it running... I see my ice coffee tipped over in the drivers seat. Now I don't know if I'm more relieved there is nothing (new) wrong with my tractor or more pissed off that I spilled my coffee...
