Rear auxiliary power supply?
Barner
M7060, MX6000, BV4160
May 8, 2025
Alabama
I recently purchased a new MX6000 rops and then ordered an air ride seat. While installing the seat the first thing I figured out was the instructions didn’t match the tractor. I was able to modify the bottom of the new seat to attach to the old seat frame. Worked out pretty well. Ordered the extra wiring harness to connect the old OPC connector to the new seat and that worked as well. Now the problem is the instructions say there are 3 auxiliary power connections back there and you just simply plug it in and away you go, only they are not back there. Or if they are I can’t find them. There is a large brown connector just hanging out that I am assuming is power but don’t know that. The picture shows the brown connector I mentioned as well as the male power supply connection for the seat to air up. Any ideas or suggestions are appreciated.
8,805
That 8-pin connector looks like the trailer connector.
