Rck60b23bx
laketractor
BX237, 60" MMM, Box Blade, Landscape Rake, FEL, Tow Spreader, Tow Sprayer
Jun 25, 2015
11
Changing the gear case fluid on the top of my 60" MMM is a messy pain in the butt. Anyone have a suggestion to make this easier?
6,384
Did you pump it in or try and pour it in?
I have a few pump and tube set up for just such tasks. ;)
3,309
pull the plug onthe side and a small funnel when it starts to come out the side hole your full..If you dont and fill it up, when it gets hot,,,:eek:
5,207
1,893
I suck it out, but I bought an evacuator, or more specifically I built my own version of one using their parts before the metal ones were available. Takes about 15 seconds to suck the oil out.
Turkey baster with a small piece of fuel line attached works pretty good too, but takes longer.
L4740
222
3rd Rock From The Sun
I put a chain on it and lift it up vertical with my loader. Then position it so that it leans back so when I pull all the plugs it drains into a drain pan.
