Lost a seal and ruined the gears on part # K5761-33315 Case. I need the 2 bevel gears part # K5761-33320. Does anyone have an gear case from a deck that is wore out? Or just the gears? Let me know. THANKS
gears are expensive. And they're usually shredded, that's what's usually wrong with the gearboxes. So, finding a good used one is unlikely. Finding the correct gears on the used market even more unlikely. Always worth a try though and I hope you find a set that will work for you, as those gears themselves aren't cheap-and shimming them to set them up properly is no fun to do.
Agree with Lugbolt on this one. Lost the bottom gearbox seal in my RCK60-24B MMM. My gears were shredded and metal was throughout the gearbox components. After pulling together a schedule of parts costs and from experience having to accurately shim the components..... I knuckled under and bought a new gearbox assembly...complete with the pulley keyed and pressed on the spindle. Cost me a Grand and taught me a lesson to play closer attention for evidence the seal is letting go. Good luck! Butch
