Rcf2072 dishpan
bbencker
US
I need to put a new dish PAN on my R. C. F2072, it originally had a 30 inch dish PAN. The dealer sold me a twenty four inch dish. Pan, they had in stock with longer blades. My serial number falls after the manufacturing split, and online searches say it requires the thirty inch pan due to the gearbox changes. Is this truly the case, or can the twenty four inch go on with longer blades? Thanks in advance
11,183
Like to help you out, but I don't find a RCF2072 or any variation of that.
Serial number ?
Picture ?
Part number of what you got?
JasonW
886
588
Al
Shows up as a land Pride rotary cutter. But yes a serial number would help.
Did you need to buy blades also? Or the dealer just trying to sell what they had on hand?
bbencker
US
Serial number 1503859 everythingnI tead says the later production numbers, which this one is, cannot use a 24 inch pan for multiplenreasons
bbencker
US
I was going to order the 30 inch pan but they had this in stock from a misorder and sold it to me with a set of new longer blades. But Ive been told the 24 inch could harm the gear box
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,947
2,451
WestTn/NoMs
The parts list indicate that at some point in the production run, LP went from a 24" carrier to a 30" carrier with shorter blades. But the gearbox wasn't changed, so the carriers must be interchangeable. I don't know why they changed. What is/are your online search sources?
The 2060 also had a 24" carrier, but not the same part number. Is yours correct for the 2072?
11,183
As long as the blades match the pan you will be fine.
