RC54-??? (part of label missing) on B7200 HST. With the splined fitting and the 2 Belville washers and blade in place, and the blade bolt torqued down, the blade is still just loose enough that blade speed does not match spindle speed. Natch, gets hot as hell when trying to mow.
The Belville (cup spring) washers are probably as old as the tractor and would be my first suspects, but there does not seem to be any difference when I swap the blades, washers, and splines from one spindle to another. Grass is getting higher while I try to figure this out. Driving me half-nuts.
I may replace all six of the Belvilles if somebody can suggest a place to get them at a reasonable price, even if that is not a source of the present problem.
