Rated speed?
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
And if you change the engine speed on an hst, the ground speed changes. So ground speed is a function of rpm
You guys crack me up.
Zero ground speed can be accomplished with engine off, engine at idle, and engine at max rpm. Ground speed is completely independent of rpm.
But wait, at full forward HST pedal, you can adjust ground speed by increasing or decreasing rpms. Ground speed is directly a function of rpm.
Wow, you're both right, and none of this has anything to do with rated speed.
Good entertainment though ;)
