I finally got around to some finishing touches. I ended up replacing all the u-joints in the driveshaft train as well as the bearings supporting the shaft that becomes the "front" PTO. Then I added, the snubber chains I mentioned, to prevent lifting high enough to separate the drive shaft halves:
Then I motorized the chute rotation and deflection. For deflection, I used a 4" linear actuator. It's still a bit on the slow side, but much better than the 8" one I used on the rear blower.
I found the power window crank motor on the rear blower to be too slow too. Plus, there was insufficient room to mount something like that on the front blower because of the FEL arms and bracing. I needed to keep the motor over the blower tub rather than hanging off behind.
So I opted for a chain driven setup, utilizing a MIG welder feed motor. I really like the resulting speed -- about 6 seconds. Not so fast as to be touchy, but quick enough to be responsive.
(I'm not sure if this will work, but let's try embedding a video clip here too)
(nope, it didn't work. If you want video,
click here.
It's not really practical, and I would probably be better off with a blade at the rear or a bucket at the front, but I do think this looks cool:
