Quick hitch problem
jay2
139
kington, ohio
Added a quick hitch. One problem, when I raise and lower the blade, the two bolts that hold the top hook on the QH hit the top mount for the blade. See picture. Any thoughts how to fix this?
Thanks'
Jay
Wbk
307
St Adolphe Manitoba Canada
Thanks'
Jay
Hi Jay, what i did with mine was i used a cut off blade and cut the adjustment part off of the hitch. I welded a flat plate across, then figured out where my hook should be and welded it to the plate. It works fine but now you have no adjustment, there is another company that mfgs. one that turns the adjustment plate sideways then welds the hook to a plate and it slides up and down without any obstruction. another option would be lenghten the hook so your adujustment holes are higher up. I hope this helps Barry
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
Mine hit also but, no problem. I have a set of torches, a plasma cutter, a band saw and 2 welders. Problem solved. ps,, I love modifying stuff!!
