Added a quick hitch. One problem, when I raise and lower the blade, the two bolts that hold the top hook on the QH hit the top mount for the blade. See picture. Any thoughts how to fix this?
Thanks'
Jay
Thanks'
Jay
Hi Jay, what i did with mine was i used a cut off blade and cut the adjustment part off of the hitch. I welded a flat plate across, then figured out where my hook should be and welded it to the plate. It works fine but now you have no adjustment, there is another company that mfgs. one that turns the adjustment plate sideways then welds the hook to a plate and it slides up and down without any obstruction. another option would be lenghten the hook so your adujustment holes are higher up. I hope this helps Barry
