Can someone recommend an economical quick hitch for my L2350. Does it need to be category 1 or 2 or one for both? Brands to stay away from? It will not get heavy use. Basically I will use a 5 ft box blade, 5 ft finish mower and possibly a boom pole.
Well harbor frieght QH is the most economical.
You need a Cat 1 Quick hitch (as that is what the tractor is), but you will need bushings or pin changes on the equipment as the QH has cat 2 hooks on it.
You might have issues with its use on the Finish mower and boom pole, depending their design.
If the boom pole is a standard 3 point mount no issue, if it's mounted like a post hole digger (center link directly to the tractor) then it won't work.
For the mower, if it has a floating top link you will need to purchase the adapter for the QH for it to work.
