Question
3,316
Dose any one know if PVC glue will work on a plastic bucket? I priced uniseals and geeezzzz of petes are they expencive, so I figure drill a hole inthe bucket as close to the same size as the PVC pipe and push a piece of pipe through and then brush glue around it,, any ideas, cause I have no idea
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
I would look into the threaded PVC to try and secure it better. I would also use epoxy over pipe glue.
ccoon520
L2501 w/ FEL
Apr 15, 2019
360
106
IA
A bulkhead fitting might work better. You'd just need to find one that works with curved surfaces.
2,555
ccoon520
L2501 w/ FEL
Apr 15, 2019
360
106
IA
Also if the bucket is empty at the time of assembly you could try an epoxy and try and make large chamfers on either side of the pipe. That might seal it but no guarantee.
6,384
Bulk head fittings are the best, then Silicone (RTV) sealant, or better yet Lexel.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Ok call me cheap I had couple of rubbermaid water tubs get cracked I used flex seal tape both sides. Then flex seal spray thin coats then faraday 2 to 3 coats. I still use them today been patched 2 years ago.
3,316
If I was to go with a large container for an ebb and flow system yep the bulkhead fitting would be the ticket. However experimenting, I am using buckets hence the uni-seal question and with gluing the pipe in place. I never thought about the threaded fittings that might work with the sillycone
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,120
1,242
Near Lancaster, PA, USA
How big of a fitting? You can can get an Electrical nut on it with gaskets and than silicone it up.
Yes - and if it were me, I'd maybe get an O-ring on the outside of the bucket between the bucket and and the fitting. What size? I'd imagine the larger the fitting the more difficult to seal up.
Borane4
M4-071
Dec 16, 2020
105
As a direct answer, no PVC glue will not work on a polyethylene bucket. Not many glues will stick to bucket plastic. Mechanical connections like the bulkhead ideas are probably better. Good Luck!
3,316
OK my bad,, I was kicking around a Dutch bucket set up for maters, you put a hole in the bucket about 2 inches up from the bottom put the uni seal goes in hole and a piece of 1/2 inch pipe with a 90 on each end one inside one out side of the bucket. The water flows in from he top around the plant and trickles down through the roots and pearlite untill it fills up the bottom of the bucket to the height of the hole with fitting Then drains in to a return line back to a sump and then re pumped back through the system. The ui seal is what would make it easy ,but I was wondering how to not use it, ( spend money). Looks like I have to spend the money, thanks guys
BigG
Sep 14, 2018
1,951
770
West Central,FL
I did something like you are talking about when I was teaching shop. I hung a 10 foot piece of gutter on a chain link fence with maybe 1/8 inch of slope. I put a small hole at the lower end so that it would drip into a 5 gallon bucket. For the supply side I wired a 5 gallon bucket to the fence with a hose bib attached.https://www.cbsbahamas.com/pd/bk-103-014-proline-heavy-duty-brass-hose-bibb-3-4-in-mpt-x-3-4-in-mht/62887 Illustration purposes only, seams high price but you can thread a nut on the back side to attach it to the bucket. Planted bib lettuce and tomatoes in a vermiculite / perlite mix. Filled the upper bucket with Miracle Grow and adjusted the hose bib to drip all day. it would drain into the lower bucket and simple poured it back into the upper bucket the next day. Repeat every day. Add more Miracle grow as needed to keep 4-5 gallons in the system.
You can get a lot of plants in 10 feet of space.
My plan was to add a zig zag of gutters to the 6 foot fence but I left teaching before I got to it. The city kids were amazed that you could grow you own food.
JimmyJazz
1,219
739
Pittsburgh, Pa
Gorilla Glue. Amazing stuff. Readily available and inexpensive. I have use it for many things including glueing 5-10 pound stone back into position on the exterior of a house for shits and giggles. That was several years ago. Still strong. I reckon that may qualify me for the Hillbilly Of The Year Award.
