Question
shiraz627
BX23S Piranha toothbar, Underarmor, PFL1242 pallet forks, BXpanded thumb, ripper
Aug 1, 2018
206
Kingsland. GA
I was looking at a used BX25 TLB. When I was driving the machine around I noticed that the tractor did not stop completely when I let off the gas, I had to tap the reverse peddle to get a full stop. Is this normal operation?
troverman
Jun 9, 2015
1,188
268
NH
If you are in high range, sometimes the machine will keep rolling slightly. Especially if you are headed downhill, but even on flat ground. It shouldn't do this in low range.
2,223
Not normal.....
grease it as mentioned - there is a small little place near your right foot in the rubber mat.....pull the quarter size piece of mat back and look in the hole in the deck........there is a zerk hiding in there!;)
