Question on B 2601
3,309
I am wondering about the rpm range on the 2601.. Full rpm range is, well I dont know what it is for sure, but it wont go past the mark for the PTO on the dial. Im wondering because the BX 2360 seems to spool up a lot faster and higher, at least sound wise, and doesnt seem to lug down on inclines.
B737
LX3310
Jun 9, 2019
2,024
2,200
about the same for mine Skeets, doesnt go much further than the red PTO hash mark.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
327
508
NH/VT NEK
Same. And so far I haven't found any desire for more.......
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
344
128
St. Louis, mo.
Skeets, the sweet spot on mine is 2200 rpm, has never bogged down using loader for digging, rock hauling and using the 60” mid mount mower cutting 12” high grass. I can’t comment about the pto don’t use it much. Even though we both have b2601 I suppose every machine is a little different in its operation capacity?
2,965
I run my B2910 full out only if I am using the brush hog, which I rarely use these days.
For almost everything I run about 2000 RPM or less. No need for more. Maybe 2200 if I am in a hurry, but that is rare.
If you are curious, after normal break in, you should be fine just running it up to max and seeing what that is...That is what I would do if I were curious.
I run my BX2200 at full throttle when cutting grass, which is its main function, and have no clue what the RPM might be. No tachometer...
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
237
87
S.E. TN
I mow at about 2500 and maybe a little less for anything else. I’ve mowed before at 2200 and it was ok, but went to slow for me.
