Question about hydrostat fluids
volfire48
B2100
Apr 24, 2010
west tennessee
I'm new here so sorry if this has been covered. I have a B2100 that takes a little more than 3 gallons of 10w-20 hst fluid. Dad has a T1460 lawn mower that holds about 2.5 quarts. Thought i would get a 5 gallon bucket of a good hydrostatic fluid and do both. The problem is the 1460 manual recommends 20w-30. Talked to guy a local kubota shop and he said to go ahead and use the 10w-20 in both. Anyone know or have any suggestions?
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
You might look at the Shell Donax TD, that is what my L3410 takes. My JD 425 Garden Tractor will take the same. If you use them allot in very cold weather you may consider Donax TDL.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Thats kinda of strange since most Kubota's its recommended to use UDT or Super UDT in the hydro systems.
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
Bad advise if you ask me. Needs UDT like Eric said.
Sounds like my dealer, needing to work on something broke.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
If you want the best protection for yor ride I recomend Amsoil Tractor Transmission/Hydrolic Oil. It's a 5W30 weight oil. It will make it run up to 70 degrees cooler in the summer and will allow free unrestricted movement in the winter as well.
stevecudo
Montrose pa usa
help!!!!!!! I own a tg1860g hydro,,, need to know the best way to check fluid leval. It looks like the only way is threw the breather hole. And what hydro oil to use. There is 380 hrs on the machine but it is the 2nd hydro. Should I change the fluid is there a filter??? can't afford to put a 3rd hydro in it please give me a clue thanks
6,657
I would say you need to buy both the owners and service manuals for your tractor, it will spell everything out for you so you can save some money down the line. ;)
