My BX22 of 13 years just had a failure, it looks like the rear differential lock failed and put a crack in the transmission case from the inside out like others have reported. I called the dealer today to get a "guesstamate" and see that I need to remove some items from the BX22 to lessen the labor charges. Since all my Super UDT2 fluid leaked out I cannot/don't want to operate the engine. All I see are videos on how to remove the backhoe in about 1 minute when you can run the engine and have hydraulics. My question is how can i remove the BT600 without using hydraulics...........I probably need a jack and some ramps and a strap to pull the tractor forward which is in the middle of the driveway right now. I have plenty of room on all sides to do whatever I need to do.
