Who has tore into an engine and found something that has been into the engine since the factory that was not suppose to be there. I had to replace the head gasket on my skidsteer which has a kubota engine in it. I knew I had a bad injector also so I had them pressure checked and replace one. It so happen this was on number 3 cyl, same place as the head gasket was bad. The exhaust manifold was almost plugged on this cyl which I thought was carbon. I went to fix that before installing and found out it was a big ball of casting from when the manifold was cast. I tried grinding it but was messy and took to long so I set it up in my milling machine and cut it out. I had to cut almost an inch of metal until I got the hole opened up. Cannot wait to try it out to see what difference it will make
