My grader scraper and rotary cutter both have a short section of lower 3pt pin bordered by flatbar that is drilled for the pin. The grader scrapers is about 2 7/8 between the flatbar and the rotary cutter is about 3 1/2 inches.
It seems the bushings aren’t available at exactly the right size, so I might have to cut to fit to have a tight fit. As wide as the bottom hooks are on the QH15, it seems close would be better and I could keep the factory coating on the bushing instead of loosing it on the cut side of the bushing.
If you use a QH15, do you try to fill the entire distance between the flatbar with a spacer, most of it, or just use the short bushing type?
