Putting weight on the front of Bs
mike paulson
228
24
ulster, NY
mbnorton
canada
Weight doesn't push traction does...
so to continue on with my theory. If he has all kind of weight on the front due to the front blade. Remove some dirt from scoop. May have enough weight on rears for the proper traction because he has chains. Or remove scoop completely and add some rear wheel weights directly over the rear axles. I didn't say removing the scoop would work I said just try. may be cheap fix.
Russ no hard feelings. Just different ideas;)
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
Yeah, proper application of weight is clearly key. Doesn't help much if the added weight is over a fulcrum (like the front axle that may be damaged due to excess traction) and lifting weight off the traction surface for the primary drive.
