Any of you fellas ever lift your tractor on a two post automotive lift, and if you did how did you do it?
I was thinking of making a crossmember that would go across the lift arms and under the rear of my b2620. The front isn't a problem, the lift arms can easily be situated under the loader frame.Yes, bx2230. 2 of my arms curve and I put them around the back tires under the rear frame. I took a 2 inch square by1/4 inch thick tube about 5 ft long and made some hooks (2, set as wide as the frame),in the center that would hook under the front frame and set the tube on the other arms of the lift. Sorry, I don't have pictures of it.
