Every year on halloween we do a hayride where I use my tractor to pull a trailer situated with rails and hay bales for seats. In the past I've towed conventionally my 18' equipment trailer, weighing in at 3300lbs empty. I no longer have that trailer, instead having moved up to a 30' deckover gooseneck, weighing 5600lb empty.
My towing tractor is my MX4800. With the conventional-tow trailer, I used a ball mounted on the drawbar. However, with the gooseneck, I'd have to use a 3-point hitch gooseneck frame and ball attachment.
The area we do the ride on is 100% flat, and lawn. About 5 acres.
The tractor will have a loader with a bucket or forks on it, and has loaded rear tires, so I'd say it weighs a little more than the trailer.
Can the 3-point hitch lift this gooseneck? Will the tractor safely pull it?
I think the answer is yes, but thought I'd get opinions.
