I have a B2710 that will puke hyd fluid out dip stick tub while running fel. What will cause this. Thanks for any help.
No it’s not.You have a blown pump seal.
Is it a stock FEL?
You also will need to check pressures to make sure the relief valve is working properly.
Well then it's very likely that its plumbed wrong and it's deadheading the pump and blowing the pump seals.No it’s not.
Your probably right. How would I go about finding the correct way. I really know nothing about troubleshooting something like this.Well then it's very likely that its plumbed wrong and it's deadheading the pump and blowing the pump seals.
Post some pictures of the piping to and from the FEL valve.Your probably right. How would I go about finding the correct way. I really know nothing about troubleshooting something like this.
Are we talking about the engine dip stick, or the transmission dip stick?I have a B2710 that will puke hyd fluid out dip stick tub while running fel. What will cause this. Thanks for any help.
AWWW good catch... I made the mistake of just thinking engine.Are we talking about the engine dip stick, or the transmission dip stick?
TransmissionAre we talking about the engine dip stick, or the transmission dip stick?
If it's the transmission, I would check the vent. If it's the engine, then Wolfman's got that covered.
Sent from my LGMP260 using Tapatalk
Fluid and filter was changed about 4 months ago and used all Kabota parts and fluids. It stays outside in barn or shed. There’s also a rubber hose running down around gas tank that fluid come out of it to. Thinking this is the vent tube.Ok, my apologies for bad info, not a pump seal issue!
Now for the transmission dipstick issue, new O-ring's on the dipstick if it's not tight in the tube.
Check the vent and make sure it's clean.
Could be foaming of the fluid, this can be caused by a leaking suction line (you might not see fluid, or a slight amount seeping leak on the hose or fittings), or water in the fluid.
Yes
When was the last fluid and filter change?
What fluid and filter did you use?
Is it stored inside or outside?
More likely a suction hose that is breaking down on the inside, and that is your air leak.The fel was used nearly a year before this issue started,by the way when I cleaned screens last week I found a very small piece of green rubber, did this come from a seal in the pump
Nope that's a pressure side leak, I'm talking about a suction side leak.The fel slowly leaks down when it is raised could that be the trouble
