PTO Wood Splitter Questions
bucktail
Jun 13, 2016
1,299
221
MN
Couple of reasons. Primary one is GPM from your tractor. I'm not sure how much the BX puts out, but since the OP appears to have done his research regarding how much flow he needs I'm assuming it doesn't put out enough. My L1500 puts out 2.8 GPM. You'd measure cycle time with a calendar. Most of these compact tractors run around 2000 PSI, so if you'll need to step up to a bigger cylinder to get the same force as something running 3k making problem 1 worse.
Not relevant to this thread because he's talking about running the splitter with a PTO, but a lot of folks like to have their tractor free to use the FEL to handle wood rather than run a splitter, which would drive the decision to a self powered splitter.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
I've got a tow behind splitter that I have had for years and it works great! I don't tie up the tractor while I split and I have a trailer I pull behind the tractor that I park next to the splitter and throw the split wood and then drive it to the house where I stack it in the wood shed ready to go in the fall. I just leave the splitter by the wood to split and cover it if I leave it overnight. That way, the tractor is always free to do something else.
