PTO wood chipper
nbryan
Jan 3, 2019
1,427
947
Hadashville, Manitoba, Canada
If you’re planning to handle a lot of brush, logs, and small trees with your L6060, going with a PTO chipper is a smart long-term move compared to renting.
The Woodland Mills 8” PTO chipper is generally a solid mid-range option. It’s known for its durable build and consistent performance, especially for property owners dealing with regular wood cleanup. It offers a good balance between price and reliability.
There are also a couple of other brands worth looking at. WoodMaxx is often mentioned for its heavier construction and slightly more rugged feel, while Titan Attachments tends to be more budget-friendly, though quality can vary a bit.
For a tractor like the Kubota L6060, an 8-inch PTO chipper is a good fit in terms of power and efficiency. Just make sure you’re checking PTO HP compatibility and overall build quality.
Also, if you’re comparing different agricultural machinery parts and tractor attachments, it helps to look at suppliers that focus on durable OEM-style components rather than just price. That usually makes a difference in long-term performance.
Overall, Woodland Mills is a safe bet, but comparing a few options before buying is definitely worth it.
Love my WC68 on the B2650! 19HP pto does the job.
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
281
677
wisconsin
ive had deliveries come both with straight nirmal semis no lift gate and with lift gate. i unload in front of the property the two instances with no lift trucks the driver got the load close enough i could fork it from the end. i always ask for a lift gate if its an option.
i always communicate with the shipper what i have and there is no dock
NordTrac
MX5200HST, BH92, LA1065, SB78-PT, V-4021
Jan 26, 2025
73
223
Quebec, Canada
Assembled and tried out the new TF810 PRO. What a beast with the MX!
Here it is with the all-around fairy!
fruitcakesa
M4 071
Oct 26, 2010
892
308
Cavendish Vermont
I just checked for a PTO override switch on my M4 and to my dismay it doesn’t have one as confirmed by the operator manual 😞.
Now I’m going to have to jury rig something so I can use the wood chipper and winch.
It has the fixed Grammer seat.
11,757
Engage the PTO and stand up out of the seat and an alarm will sound in the cab for about 5 seconds but the PTO won't disengage. That's how my M6060 works and I have the Grammer seat too.
