PTO Shaft fluid leak
JoeMc7868
MX5200
Jun 5, 2026
Jamaica2003#
mx5200 pto leaking oil from the back around the shaft. Can i replace the shaft seal from the outside or do i need to take the bearing cover off and press it from the inside. What is missing?
2,963
Not sure you can get to the Kubota Illustrated parts list from Jamaica but try this site
This is the HST version of the MX5200 but your tractor may be a different model (DT or F). But this part of the tractor is PROBABLY the same.
Look at the 4 parts listed in the upper RH corner. Those are what I think seal the oil in. Three of them are internal, only the “wiper“ is external. One is a sleeve (collar) that fits onto the shaft that the seal rides on.
