Pto noise
Jtryan
B2320
Jan 17, 2016
55
Ottawa, Ontario Canada
I just installed my snowblower on my tractor and tried it out. When I raised the blower all the way up I heard knocking noise from pto area!
Is this because it was to high when running pto?
4,627
It may be your PTO shaft has no more room to collapse on itself, then causing a bind on everything it's attached to. Definitely not good.
Grouse Feathers
Feb 16, 2015
1,022
9
Lovells, Mi
As the angle across a universal joint increases the speed of the output shaft increases and decreases twice per revolution and can cause a knocking noise. Only raise the blower as much as necessary when the PTO is driving the blower.
With two universals on a automotive drive shaft the input and output shaft remain parallel even when not perfectly aligned. The angles are equal and opposite and the speed changes cancel each other out (the input and output speeds remain the same).
1970cs
1,124
Grand Ledge
A little more input! Is this the first time it's been hooked up and ran? Great points posted above. Also do you have two heights or positions on the blower frame where you can remove the class 1 mounting pins and change?
Pat
CountryBumkin
Sep 27, 2015
568
Central FL
Pay attention to Pat's comments about PTO shaft being too long. Others on this forum have damaged their tractors with long shafts.
I would disconnect the PTO shaft then raise the blower to full lift height, and then with one end still connected see if the shaft has room to collapse further. You should be able to collapse the shaft enough to attach the shaft to the PTO now. if you can't get the drive shat on the PTO now, it is too long.
Jtryan
B2320
Jan 17, 2016
55
With two universals on a automotive drive shaft the input and output shaft remain parallel even when not perfectly aligned. The angles are equal and opposite and the speed changes cancel each other out (the input and output speeds remain the same).[/QUOTE
I never thought about it when I raised it until I started to hear that noise then dropped it back down... would it have damage something in tractor?
5,475
You probably did not hurt anything, raise it half way then if no sound your fine.
PTO shafts extend out when you lift,not get shorter, so it's not an issue of the shaft being to long.
Grouse Feathers
Feb 16, 2015
1,022
9
Lovells, Mi
Raising the blower high enough to make a knocking noise once or twice a year by accident probably will not damage anything. Continuing do raise the blower that high would probably damage the universal joints first. Continuous operation with the blower raised too high could cause shock loading damage to gears in the tractor or blower.
Jtryan
B2320
Jan 17, 2016
55
Ok so I shouldn't worry about it then? Wasn't a pleasant sound, it maybe did it for 30sec before I realized what it was
