PTO for Fransgard Forestry Winch
Beebad
Kubota L-3560 HTC
Oct 12, 2024
39
Northern New Hampshire
My L-3560 generates 29.5 hp at the PTO. about a class 1?
i have a fransgard v-3507 forestry winch that need the QD splines at both ends.
most everything I find has a round end or one with the slip clutch. (How hard is it to remove clutch and add a qd spline?)
I found a series1 at AGRISUPPLY but thought I should check in here first for other alternatives.
At the shortest distances between detents I measure about 26 1/2”
6,494
My Woodland Mills WC-68 chipper input shaft is the same “Type 1” 1 3/8” 6 spline stub as is on the tractor. It uses a shear bolt. You could call Woodland Mills and check their price. Screenshot of OM attached for clarity…
