problem with L4400 cranks , starts, then stops-won't run
SSPate
Quinton,AL,USA
It starts momentarily but then immediately stops. Have checked fuel, fuel filter, etc. Right in the middle of a major project and rain is coming....need help! Thanks.
5,361
2,037
Almost sounds like the fuel shutoff solenoid isn't working properly. It has 2 coils. A "pull" coil which pulls the solenoid open, then a "hold" coil, which holds it in the run position. Also, might be worth looking at the wire connector and possibly the fuses.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Did you run out of fuel or did it just start out of the blue?
Did it start just after you filled it up? May have got some bad fuel.
How long has it been since it was serviced? May simply be a plugged fuel filter.
Give us all the info you can and I'm sure somebody will be able to help.
whitetiger
Nov 20, 2011
2,992
1,448
Kansas City, KS
Check the hydro state pedal neutral switch, should be under the floor on the left hand side of tractor. The plastic insert with the wiring plugged to it gets loose in the metal housing resulting in a start and die condition. Put a plastic tie around it to pull sections together and get back to work or playing.
7,766
All three, Lugbolt, Bulldog, and Whitetiger have valid possible causes of the issue. ;)
