J jimpic New member May 28, 2012 2 0 1 calais vt Jul 30, 2026 #1 I snapped a nut off the the 1/4 threaded post when replacing water pump on l2050. Can I use tractor and see if it leaks or should I take care of this now Thanks in advance
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 7,883 3,078 113 Austin, Texas Jul 30, 2026 #2 You will probably have a leak and could overheat the engine if not monitored for temperature. I would replace it now since you probably still have access to it (from replacing the pump).
T Trash Panda Well-known member Equipment L2501 Feb 18, 2022 268 261 63 Wyoming Jul 30, 2026 #3 You’re already in there. May as well fix it now, instead of doing the work twice.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,045 11,015 113 Sandpoint, ID Jul 30, 2026 #4 FIX IT!
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 14,957 7,639 113 40 miles south of Kansas City Jul 30, 2026 #5 Yep. wishful thinking won't fix it. Reactions: 1 user
