A relevant cold weather topic has to do with portable generators.
For those companies who will post operating temp spec's, the low limit is not very low. The crankcase vent line freezes and the oil is forced out of the crankcase.
This happened to me with a Honda EM3500 in 1998 during a major ice storm. Only in the last year have I seen the issue addressed by manufacturers.
Honda provides this advice:
Cold Weather Kits
These special cold-weather kits were created to address some unusual operational issues with Honda generators operated in extremely cold environments for extended periods of time. While all Honda generators can operate quite well in cold weather, there are some very rare cold-weather conditions where it is possible for water to collect and freeze inside the crankcase breather tube fitted between the air cleaner and crankcase. When this happens, the formed ice can block air flow and possibly cause the generator not to work properly, or some oil to leak out of the engine.
To prevent this, Honda has developed a small, 10-watt heating coil that fits inside the tube and keeps the area warm enough to prevent ice from forming. The heating coil gets its power from the generator by connecting to the back terminal of a selected receptacle. Each kit is unique to a specific generator, and some come with special insulated parts to help regulate the temperature. Once installed, the cold weather kit may remain on the generator; it is okay for it to operate year-round.
Generac sells s silicone heater which runs off the generator 110 volt circuit.
It is wrapped around the crankcase vent line.
Dave
Cold Weather Kits
Dave
