pneumatic grease gun not pushing grease, front bucket pin problem
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
correct, the follower rod was still pushed in, maybe that was why all the grease pushed out
new plan: i dont want to mess up another 13 dollar container of grease, I might look into getting the hand pump ones, or electric, but at least get one working hand pump so I can grease the machine
As far as the pins go: I will look at the kubota drawings, get that part number, and see if maybe i search it on amazon and maybe they will have it
Or get a few of them from messick, that way I know for sure they'll work
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
The air pressure had nothing to do with all that grease glooping out. You didn’t pull the rod with spring loaded follower before unscrewing the cartridge.
Correct, and the metal clip that frees the follower rod, somehow went missing
In the picture you'll see it missing, hopefully the gun can still work without that part
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
messick shows part number 20, as being just a little split pin
Why then all the nails I put in it tear/shear out?
That nail is similar to that split pin
Maybe I'm so hard on it that it loosened that area, causing everything to not stay put
I'll still look into putting the biggest bolt I can fit in there
Or I might get a set of "split pins" of assorted sizes, put one big enough, maybe it'll hold
3,143
I with @fried1765 on this.
Unless there is some specific reason to use the factory "split pin" that I am unaware of, I would go with a locknut and bolt and be done with it.
mikester
M59 TLB
Oct 21, 2017
3,716
2,250
www.divergentstuff.ca
$40 dollar grease gun from amazon, put new grease in it
Put air to it, it wont pump out grease
I havent greased the machine in about 3 months or longer
Can someone tell me maybe why it will not pump out the grease?
2nd problem: here are pictures of the front pin missing, almost every hour I need to put new nail in there
Anyone recommend a pin set I can get off amazon that would fit this and others down the line with kubota tractors
The pin is actually missing on the other side, but the bigger sliding piece somehow is not sliding out
This sliding piece will slide out if no nail/pin there
here is a set for $20, maybe one of those will fit that spot?
These appear more like the original one that used to be there
I tend to try an buy my cheap chinesium stuff from Princess Auto because they are a good Canadian company and have a great returns policy
This is your guarantee from Princess Auto. “No sale is final until you're satisfied. We guarantee to make it right. We will repair, replace or refund any product to your satisfaction.”
You don't get that service from amazone mystery vendors
CDN$14.99
CDN$18.83 on clearance
5,099
From your local hardware store.....
A simple bolt, with a lock nut, is all that is needed for the "pin".
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
177
118
Villa Rica, GA
Asking the obvious, but did you pierce the foil top on the grease tube before putting it in?
update on the grease gun:
Went to a bigger compressor, still did not push out grease
Then, i noticed the bottom clip (you can see in the picture) went missing
Looked around, cannot find it
then decided to take off the grease to see if its even pressurized, big mistake
All the grease come out
I'm understanding - there is pressure in the grease chamber area, but it is not making it to the nozzle
There is a hole on the other side of what the picture is showing, on the grease on, there is a hole that pushes out air, tons of it
Sometimes, I will hear the cylinder pushing the grease forward, but most of the time,
all the air is escaping from that hole, and no grease is pushing forward
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
CDN$14.99
Yes I have heard of them from youtube mechanic, zipties and bias plias, but,
I dont think they are in the united states, maybe they are, i'll figure it out
And yes with amazon, I've already purchased a few items that had pieces missing, and to ship it back cost more than I paid for it (12-14 dollars delivered)
Their prices are even better than harbor freight, but the quality on intricate tools (like the pneumatic grease gun) could be off sometimes, maybe mine is broken
Harbor freight's cheapest pneumatic gun is $100+
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
Yes, after I am done typing, I think there are small bolts in my bolt pile that MIGHT fit in that hole
I didnt think kubota just put the "split pin" there
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
Yes, the grease gun maybe once out of 100 pulls on the trigger, WILL spit out some grease, when this happens,
I confirm that you feel the hydraulic motion inside the gun moving the grease forward, but
most of the time, all the air comes out from a hole on the right side of the grease gun
Some kind pressure release
Deep inside the gun, the motion of taking the grease from the pressurized chamber into the grease hose, cannot be done 99% of the time
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
I did get a $17 dollar hand grease gun, the "overall choice" on amazon just to at least get some grease in that machine
Holding off on tinkering with the pneumatic gun for now
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
Bucket splitting in half
Now there is a problem bigger than the grease/pin
The bucket is splitting at the welds
I was running it very hard flattening ground, then i noticed it
I dont think it was there before today
To be fair, I've moved more earth than it was meant, have gotten big value from it
Dont think that a little bx1500 cant destroy a bucket, it can
I'm still gonna run it, but I know later to hammer then weld it back in place
I'll try not to run it flat, but rather crab walk
Since running it flat is just gonna keep bending it inward...
MOOTS
MX6000
Jun 27, 2019
2,048
2,466
Canton, Georgia
The bucket pins are meant to move some. The small bolt, or in this case the split pin, keeps that pin from coming out. Your first post says you haven’t greased this thing in awhile. The bucket pin is getting in a bind while working the bucket and shearing your small nail.
6,003
Before more damage is done why not take an angle grinder and clean up around that joint. Lay a3/8" rod in the crack and weld it across the entire seam? Easy fix now, not so much if you rip it open.
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
I’m still running it
It is getting worse,
yes @D2Cat, I will be learning how to weld soon from yall/youtube
At the moment, no welder available
I know, I wish I did not have to further misshape the bucket, but I am almost done leveling the area where I need to surgery on the bigger unit, hole in the side of the block
I almost have a covered area where I can take apart the engine, split the tractor, etc
Here's a bolt I found to put in that pin, it is somehow staying in
I have been thundering pushing it to the limit, and bolt not fall out yet
6,003
Joe, you never disclosed your location other than Earth, but the way it's going just wrap some electrical tape around that bolt. You'll be fine! ;)
joesmith123
L295DT, BX1500
Mar 18, 2023
596
163
earth
yes I am with you about doing more damage to the bucket, and I do not like the way it is folding
But, I am so close to having that area to do the repair work
Yes, i will be repairing the bucket once I am ready to understand and setup the welder
That bucket has paid for itself so many times the beating I have put it through the past year
