pneumatic grease gun not pushing grease, front bucket pin problem
joesmith123
L295DT, BX1500
Mar 18, 2023
499
111
earth
$40 dollar grease gun from amazon, put new grease in it
Put air to it, it wont pump out grease
I havent greased the machine in about 3 months or longer
Can someone tell me maybe why it will not pump out the grease?
2nd problem: here are pictures of the front pin missing, almost every hour I need to put new nail in there
Anyone recommend a pin set I can get off amazon that would fit this and others down the line with kubota tractors
The pin is actually missing on the other side, but the bigger sliding piece somehow is not sliding out
This sliding piece will slide out if no nail/pin there
here is a set for $20, maybe one of those will fit that spot?
These appear more like the original one that used to be there
5,066
Joe:
A nail is not a suitable "pin" for THAT application.
You need to put a proper diameter BOLT (with nut) in that spot!
joesmith123
L295DT, BX1500
Mar 18, 2023
499
111
earth
Joe:
Yes,
I will look through the hardware and make something work
in the meantime, I will wait to see the responses about ordering a kit filled with pins of all sizes that is budget friendly (instead of 1 pin from messick for $30 delivered)
Also with the grease gun:
If i unscrew the grease hose, it still does NOT push out grease
I know its probably something I forgot to do, someone knows
4,829
all guns have a 'purge' plug.you unscrew it,pump a few times, when grease comes out, tighten the plug, good to go....
joesmith123
L295DT, BX1500
Mar 18, 2023
499
111
earth
update on the grease gun:
Went to a bigger compressor, still did not push out grease
Then, i noticed the bottom clip (you can see in the picture) went missing
Looked around, cannot find it
then decided to take off the grease to see if its even pressurized, big mistake
All the grease come out
I'm understanding - there is pressure in the grease chamber area, but it is not making it to the nozzle
There is a hole on the other side of what the picture is showing, on the grease on, there is a hole that pushes out air, tons of it
Sometimes, I will hear the cylinder pushing the grease forward, but most of the time,
all the air is escaping from that hole, and no grease is pushing forward
4,829
maybe that silver button near the base of the black cone ??
if all else fails, maybe read(well look at) the manual that came with the gun ??
one thing for sure, confirm the air pressure at the gun !!!
joesmith123
L295DT, BX1500
Mar 18, 2023
499
111
earth
I tried pressing that button, it did not make any difference
4,772
Make a call to the manufacturer in China and ask for instructions on how to remedy the problem. :ROFLMAO:
joesmith123
L295DT, BX1500
Mar 18, 2023
499
111
earth
Yes I might have to do that, i doubt they can help, maybe it is broken, it was the cheapest one available on amazon for $40
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
920
1,167
Pittsburgh
The grease escaped because it looks like that gun has a spring loaded follower... that you did not disengage
5,066
I have a Lincoln (brand) pneumatic grease gun,..... it sits on the shelf.
Tried it ONCE.
PITA dragging an air hose around.
Bought a DeWalt 18V battery powered gun.
LOVE it!
4,829
Had one of those 'garage style' units on wheels, 30gal grease, 1/2 full....used it 2-3 times..PITA draggin air hose..got rid of it fro price of 3 new hand style units.
3,298
My old-reliables…no hoses, batteries, or troubles:
(5 of ‘em, each with a different type grease for different services:
MOOTS
MX6000
Jun 27, 2019
1,890
2,159
Canton, Georgia
this is the second grease gun I broke/mig
dont I know that there is pressure in the gun since it pushed out all the grease when i unscrewed the grease holder?
The air pressure had nothing to do with all that grease glooping out. You didn’t pull the rod with spring loaded follower before unscrewing the cartridge.
5,066
I dunno....
From his picture, it does seem as though the follower rod actually may be pulled back.
Kinda hard to know for sure!
2,678
😂 😂 😂 😂 I'm laughing with you, not at you....😂😂😂😂😂😂
BTDT....hahahah
I can hear myself, cursing myself out right now!! hahahah
