ShaunBlake
All great advice, Fisheye.
Sounds like you've started right, in low range, low gears. Also it sounds like your throttle is about where I'd set it, and use the pedal if it started to bog a bit.
So howcome it ain't workin right? Do what comfun1 suggested and I expect you'll find that your 3PH isn't letting the implement lower enough to really engage the ground. As a quick fix, back the nut off the end of the top link, and unscrew your top link an inch or two, then try it again (there's still plenty of thread still in it on the implement end). It looks like it is in the lowest hole on the tractor so you should be able to bury the thing to the end of the arms (if it had enough horsepower
Even if the MB isn't the ideal tool, you should be able to get it to plow for you enough to decide if you want to use it for the whole field, or borrow/rent a CAT-I implement that would make it easier.
Thanks for the pics, makes it all much clearer now. Please keep us updated on your progress!
