Plastic Threaded Plug upgrade M series
KubotaL185DT
L185 4x4, L245H, M5140HD, Case 580B Hoe, JD350 Dozer, JD LX178,
May 6, 2010
81
Northern Calif
Looking for the Plastic (Nylon)? Cap,* that is used* to seal Hydraulic/Transmission fluid reservoir fill port it is located at the rear of tractor slightly above the PTO Cover (Shield).* I can not locate it in the Kubota illustrated parts list Online, mine has been cross threaded.* I do not know what Kubota calls this threaded plug* in the Operators Manual it is referred to as a Oil inlet. ??*
Looking for a part number AND what Kubota Calls this item ?*
Is there an alternative that I can use for replacing this plastic cap Wouldn’t a metal Cap not be so easy to cross thread ?
Is there a fix for this like a metal plug or ?? Thanks
5,312
When asking about parts, don't just give a general "I need a Threaded plug for an M", it's like saying I need plugs for a truck.
You might end up with way wrong info, so give complete model info.
I'm going to assume that it's for M5140?
If it's not then the part number could be wrong.
Plug
P/N 38240-21410
O-ring
P/N 04816-50300
They have made them out of plastic for many a year, it's better to mess up the threads on a cheap replaceable cap than it is to mess up the threads on an expensive housing.
If you think you'll strip it again, buy 2. ;)
KubotaL185DT
May 6, 2010
81
Northern Calif
Plug
P/N 38240-21410
O-ring
P/N 04816-50300
Thanks you are correct its for a M5140
I mean't to place my model but spaced out as I been looking for a p/n all morning. I didn't strip it previous owner must have. I am changing Hyd/Trans fluids for 600 hrs. Thanks Bill
