M Montana Rick Member Equipment L2550DT1 Oct 16, 2015 33 0 6 Hamilton Apr 26, 2025 #1 Is it acceptable to heat tractor pivot pins to loosen hardened grease for ease in re-lube of pivot pin channels thru zerk fittings? I have heard that it is acceptable but would like some other input...Thank you all
R RCW Well-known member Lifetime Member Equipment BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU Apr 28, 2013 9,750 6,383 113 Chenango County, NY Apr 26, 2025 #2 I never have. Never heard of it. Try to grease at use intervals that wouldn't require it. Now if it were -30F degrees , might be different story.....
